[GRASS-dev] Re: [GRASS GIS] #1132: wxNviz and wxVdigit missing from
6.4svn
trac at osgeo.org
Fri Aug 20 06:22:23 EDT 2010
#1132: wxNviz and wxVdigit missing from 6.4svn
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: Linux
Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:2 hamish]:
> I can see wanting to save nviz for a backport of the improved version,
but why was vdigit disabled? My experience with it so far on Linux has
been very good/impressive.
If there are any problems with the vdigit or nviz modules, you lose the
whole wxGUI. You can catch an exception; you can't catch a segfault.
And there are so many plausible failure modes. Most of wxGUI will work
with any reasonably recent version of Python and wxPython, but the
compiled modules will only work with the specific versions they were built
against. The binary component is written C++, which tends to be more
fragile in terms of binary compatibility.
Finally, a release is bound to get used on a wider variety of systems than
the development versions.
Leaving them in might work out, or it might just prove the old adage about
"never use a point-zero version; wait for point-one".
Ticket URL: <http://trac.osgeo.org/grass/ticket/1132#comment:3>
