[GRASS-dev] Re: [GRASS GIS] #782: Please provide swig generated stuff in distributed tarballs
GRASS GIS trac at osgeo.org
Thu Aug 26 00:28:37 EDT 2010
  Reporter:  frankie              |       Owner:  grass-dev@…
      Type:  enhancement          |      Status:  closed
  Priority:  normal               |   Milestone:  6.4.0
 Component:  SWIG (all bindings)  |     Version:  svn-trunk
Resolution:  wontfix              |    Keywords:
  Platform:  All                  |         Cpu:  Unspecified
Comment(by hamish):
 Replying to [comment:5 cmbarton]:
 > wxNVIZ and wxDigitize worked fine for me in the svn version I
 > compiled yesterday.
 which branch?
 in 6.4svn they are now disabled in the gui/wxpython Makefile.
 installed copies from earlier builds might be lurking around still.
 they work fine for me too, but the problem is if they die with an error
 they take down the rest of the gui with them, and if a user installs a
 packaged version of GRASS, and then upgrades their python or wx later, it
 all stops working (AFAIU). also the wxNviz in 6.4 is well behind Martin's
 work in the dev branches, so not an accurate representation & probable
 source of many already-fixed bug reports.
 > I thought these were only disabled for MS Windows.
 nope, since a little while ago they are now changed to be disabled across
 the board. (in 6.4 only)
 > I also thought that swig stays in 6.4.0,
 nope, it's now gone. if it's there people will expect it to stay and try
 to use it (and this was actually starting to happen too). better not to
 waste their time with what will be a dead-end effort.
 > but would be replaced by ctypes in 6.4.1.
 yes.
 > I'm assuming that this holds for Linux too.
 for all.
 > I may be confused of course, but the new wx tools do work for
 > Mac as of yesterday.
 ie wxVdigit and wxNviz in 6.4? expected.
 (I am confused by this last sentence and your first one in the post)
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/782#comment:6>
