[GRASS-dev] Re: [GRASS GIS] #1141: GLWindow.OnPaint() broken on
Windows
trac at osgeo.org
Thu Aug 26 05:03:16 EDT 2010
#1141: GLWindow.OnPaint() broken on Windows
Reporter: glynn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: nviz, wingrass | Platform: MSWindows XP
Cpu: All |
Comment(by glynn):
Replying to [ticket:1141 glynn]:
> although the wxGUI crashes shortly afterwards (in Gs_loadmap_as_short(),
AFAICT).
FWIW, this should be fixed by r43279. fmode.o doesn't help with libraries
which are loaded at run-time (e.g. via ctypes), which meant that open()
was opening files in text mode, resulting in EOF at the first Ctrl-Z byte
(\x1a), as well as performing CRLF->LF conversion.
With the !OnPaint/DoPaint change (r43280), wxNviz now works (for me) on
Windows, although using it does result in Python crashing when you quit
the GUI.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1141#comment:3>
