[GRASS-dev] Re: [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS
installer distribution
trac at osgeo.org
Thu Aug 26 06:03:16 EDT 2010
#820: r.in.wms doesn't work in WinGRASS installer distribution
Reporter: ddalimonte | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Projections/Datums | Version: svn-releasebranch64
Keywords: r.in.wms, wingrass, cs2cs | Platform: MSWindows XP
Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:26 hamish]:
> > for the trac record, the shell scripts needed the programs called
> > with their full path in the command line,
Replying to [comment:27 mmetz]:
> Not in my self-compiled 6.4 version, no changes to the local copy. My
> point was that calling the programs in question with their full path
> might be fighting symptoms and not the cause.
I think it happens on the second pass, when g.parser relaunches $0. (??)
perhaps it works or doesn't work because Windows includes pwd in the path
while UNIX does not? So if you happen to be in the same dir as the addon
script on Windows it will magically work, while on UNIX (or if you cd..),
it would not?
just an idea,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/820#comment:29>
