[GRASS-dev] Re: [GRASS GIS] #1134: WinGrass - 3D view mode crashes
GRASS GIS trac at osgeo.org
Thu Aug 26 15:51:11 EDT 2010
 Reporter:  hellik            |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  wxGUI             |     Version:  svn-trunk
 Keywords:  wingrass, wxnviz  |    Platform:  MSWindows Vista
      Cpu:  x86-32            |
Comment(by hellik):
 Replying to [comment:2 hellik]:
 > Replying to [comment:1 hellik]:
 > > Replying to [ticket:1134 hellik]:
 > > as a side note, I've tried tcltk-nviz in the selfcompiled wingrass7
 and there are similar error messages, for example:
 > > > D3/5: GS_load_att_map(): elevationg7 at g7 not loaded in correct form -
 loading now
 > > very interesting, because in a self compiled wingrass7 from yesterday
 (r43155) tcltk-nviz was working.
 > > Helmut
 > tested with WinGRASS-7.0.SVN-r43232-1-Setup.exe from
 > http://josef.fsv.cvut.cz/wingrass/grass70/
 > all errors and all crashes (3dviewmode and tcltk-nviz) are the same as
 in the initial report. see also attached error-popup from tcltk-nviz
 > the same location (nc-sample-dataset), the wingrass64-tcltk-nviz and
 wingrass65-tcltk-nviz are working normally.
 > Helmut
 now tested with a self compiled wingrass7-installer at r43283,
 the 3dviewmode in the wxgui is now working, so I will close the ticket.
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1134#comment:3>
