[GRASS-dev] Re: [GRASS GIS] #1142: r.in.poly fails in LL
GRASS GIS trac at osgeo.org
Fri Aug 27 00:00:52 EDT 2010
 Reporter:  hamish       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.0
Component:  Raster       |     Version:  svn-releasebranch64
 Keywords:  r.in.poly    |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by helena):
 I copied both of your files above into a txt file and used it with
 r.in.poly and it worked. r.digit worked as well.
 I went back to the original email and copied the file again and it worked
 fine. And I made sure the region is set right.
 I bet that they had something wrong with how the region was set up
 although the region coordinates that they sent were Ok.
 So I think you can close it,
 Helena
 P.S. Among several files with different formatting that work, I still have
 this one that is giving NULLs
 (perhaps some typo that I don't see)
 AREA
  78:25:00.0W 35:82:00.0N
  78:00:00.0W 36:20:00.0N
  77:70:00.0W 36:13:00.0N
  77:84:00.0W 35:85:00.0N
 = 1 coord
Ticket URL: <https://trac.osgeo.org/grass/ticket/1142#comment:1>
