[GRASS-dev] GRASS 7: v.in.ogr segfault
Markus Neteler
neteler at osgeo.org
Fri Aug 27 09:30:29 EDT 2010
I am importing the national boundaries of Italy as SHAPE file (UTM32) which has
been generated from two parts in QGIS (SHP merge tool).
GRASS 7.0.svn (patUTM32):/tmp/ddd > v.in.ogr
italy_limits_minambiente_full_UTM32_WGS84.shp
out=italy_limits_minambiente_full_UTM32_WGS84
Layer: italy_limits_minambiente_full_UTM32_WGS84
Counting polygons for 1 features...
Importing map 1 features...
100%
Building topology for vector map
<italy_limits_minambiente_full_UTM32_WGS84_tmp at PERMANENT>...
Registering primitives...
4148 primitives registered
336414 vertices registered
Number of nodes: 4148
Number of primitives: 4148
Number of points: 0
Number of lines: 0
Number of boundaries: 4148
Number of centroids: 0
Number of areas: -
Number of isles: -
WARNING: Cleaning polygons, result is not guaranteed!
Break polygons:
100%
100%
Remove duplicates:
100%
Break boundaries:
100%
Remove duplicates:
100%
Clean boundaries at nodes:
Segmentation fault
in GDB:
41%
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff79b0d52 in Vect_get_node_coor (map=0x7fffffff8e50,
num=1754, x=0x7fffffff8cc0, y=0x7fffffff8cb8, z=0x7fffffff8cb0)
at level_two.c:228
228 *x = Node->x;
I can make the map available if desired.
Markus
