[GRASS-dev] wxnviz broken in 6.5 on Linux 64bit
Markus Metz markus.metz.giswork at googlemail.com
Mon Aug 30 07:13:49 EDT 2010
Message:
3D view mode not available
Reason: /lib/libz.so.1.2.3: wrong ELF class: ELFCLASS32
Note that the wxGUI's 3D view mode is currently disabled on
MS Windows (hopefully this will be fixed soon). Please keep
an eye out for updated versions of GRASS. In the meantime
you can use "NVIZ" from the File menu.
Problem is ctypes, the Makefiles have been backported from trunk
without adapting to the build system in 6.5.
in 6.5, lib/python/ctypes/nviz.py imports 34 libs:
# Begin libraries
_libs["grass_nviz"] = load_library("grass_nviz")
_libs["grass_bitmap"] = load_library("grass_bitmap")
_libs["grass_linkm"] = load_library("grass_linkm")
_libs["grass_g3d"] = load_library("grass_g3d")
_libs["grass_gis"] = load_library("grass_gis")
_libs["grass_datetime"] = load_library("grass_datetime")
_libs["z"] = load_library("z")
_libs["grass_vect"] = load_library("grass_vect")
_libs["grass_dbmibase"] = load_library("grass_dbmibase")
_libs["grass_dbmiclient"] = load_library("grass_dbmiclient")
_libs["grass_dgl"] = load_library("grass_dgl")
_libs["grass_dig2"] = load_library("grass_dig2")
_libs["grass_rtree"] = load_library("grass_rtree")
# 34 libraries
# End libraries
in 7.0, lib/python/ctypes/nviz.py imports only one lib:
# Begin libraries
_libs["grass_nviz.7.0.svn"] = load_library("grass_nviz.7.0.svn")
# 1 libraries
# End libraries
The same applies to all other files generated in lib/python/ctypes
The difference is caused by $(NVIZLIB) != $(NVIZLIB) between 6.5 and
7.0, same for all others in lib/python/ctypes/Makefile
In 6.5 it should read something like
date_LIBS       = -l$(DATETIME_LIBNAME)
etc.
instead of
date_LIBS       = $(DATETIMELIB)
More modifications might be necessary.
Markus M
