[GRASS-dev] Re: [GRASS GIS] #1137: wxGUI doesn't work in Windows
trac at osgeo.org
Tue Aug 31 10:45:21 EDT 2010
Reporter: glynn | Owner: grass-dev@…
Type: defect | Status: closed
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Resolution: fixed | Keywords:
Platform: MSWindows XP | Cpu: All
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:7 martinl]:
> This is problematic if globalvar.ETCDIR contains a recognised backslash
> sequence, which is quite likely on Windows. In particular, \g is used to
> insert the contents of a named or numbered group, and ETCDIR will almost
> certainly contain this sequence as part of "\grass-". This results in
the error:
I am closing this ticket, please reopen if needed. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1137#comment:8>
