[GRASS-dev] [GRASS GIS] #1226: Grass should check and warn if
g.region points to a zero area calculating range
trac at osgeo.org
Wed Dec 1 05:35:59 EST 2010
#1226: Grass should check and warn if g.region points to a zero area calculating
range
Reporter: vesnikos | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: unspecified
Keywords: | Platform: All
Cpu: Unspecified |
Grass doesn't worn are logical - eg doing raster calculations with-in a
zero area region, although valid doesn't have any sense.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1226>
