[GRASS-dev] grass modeler debug
Massimo Di Stefano massimodisasha at gmail.com
Wed Dec 1 15:38:49 EST 2010
Hello All,
i'm tring to use the grass modeler tool
first i have to say a "great thank You" to Martin and All who are
working on it ! it is a really nice tool !!!
using it i encountered few problems,
i tried it with both grass65 (grass6_devel from svn)
and with grass70 (grass_trunk) on a 64 bit debian (sid) linux.
I just make a simple model to perform a command like :
'g.region rast=myrast -p'
but i can't have it working thru the gui.
clic on the "run button" i have no output
instead i have an error log in the "Command console output window" :
### log ###
  File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_module
s/gmodeler.py", line 955, in OnRunModel
if item.GetLoopId():
AttributeError
'ModelAction' object has no attribute 'GetLoopId'
tring to save the model as a python script i have :
### script generated by the grass modeler ###
import sys
import os
import atexit
import grass.script as grass
def cleanup():
    pass
def main():
    grass.run_command("g.region",
                      flags = 'p',
                      rast = "elevation.10m")
    return 0
if __name__ == "__main__":
    options, flags = grass.parser()
    atexit.register(cleanup)
    sys.exit(main())
tring to run the script directly in the grass shell i have it running :
GRASS 7.0.svn (spearfish60):~ > ./trygrassmod.py
projection: 1 (UTM)
zone:       13
datum:      nad27
ellipsoid:  clark66
north:      4928000
south:      4914020
west:       590010
east:       609000
nsres:      10
ewres:      10
rows:       1398
cols:       1899
cells:      2654802
i also tried to save the model as a image, but  no image is generated
(and no log are printed out)
thanks for any hints, tell me if you need more detailed log
ciao,
Massimo.
