[GRASS-dev] [GRASS GIS] #1232: gui modeler don't works as aspected
trac at osgeo.org
Wed Dec 8 11:41:48 EST 2010
Reporter: epifanio | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version:
Keywords: modeler | Platform: All
Cpu: All |
Hi i'm trying to use the grass modeler in the wx gui, but i have some
problems to use it :
the "run" action do not works
i tried on both osx and linux, with grass65 and 70
tring to run the model from the gui don't print any useful log
tring to save it as script, the resulting file is not complete :
projectfile :
<!DOCTYPE gxm SYSTEM "grass-gxm.dtd">
<gxm>
<window pos="316,250" size="640,480" />
<properties>
<name>model</name>
<description>Script generated by wxGUI Graphical
Modeler.</description>
<author>habcam</author>
</properties>
<action id="1" name="g.region" pos="305,115" size="100,50">
<task name="g.region">
<parameter name="rast">
<value>bugsites</value>
</parameter>
<flag name="p" />
</task>
</action>
<data pos="110,120" size="175,50">
<data-parameter prompt="raster">
</data-parameter>
<relation dir="from" id="1" name="rast">
</relation>
</data>
</gxm>
python script generated by grass65 (incomplete) :
#!/usr/bin/env python
import sys
import os
import atexit
import grass.script as grass
python script generated by grass70 (it works from command line):
import sys
import os
import atexit
def cleanup():
pass
def main():
grass.run_command("g.region",
flags = 'p',
rast = "bugsites")
return 0
if __name__ == "__main__":
options, flags = grass.parser()
atexit.register(cleanup)
sys.exit(main())
the save as image also don't works on both grass 65 and 70
Ticket URL: <http://trac.osgeo.org/grass/ticket/1232>
