[GRASS-dev] [GRASS GIS] #1239: wxGUI command layer broken and
unusable
trac at osgeo.org
Tue Dec 14 04:06:36 EST 2010
#1239: wxGUI command layer broken and unusable
Reporter: garu | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: wxGUI | Version: 6.4.0
Keywords: | Platform: MSWindows XP
Cpu: Unspecified |
(Grass Gis 6.4.0 embedded into Qgis 1.6.0)
The command layer support of wxGUI is completely broken and unusable.
(I'm new to Grass and i don't know Python so forgive me if what i'm saying
when talking about python code is not completely exact)
1) When creating a command layer the
wxgui_utils.AddLayer
creates the text box with
pos=wx.DefaultPosition, size=(self.GetSize()[0]-100,25)
but with an height of 25 and
wx.TE_DONTWRAP
the text box is completely filled with the horizontal scroll bar and
there's no room to enter the command. To have the room where to enter the
command the height should be at least 40.
2) Even when setting the height to 40 if the entered command exceeds the
horizontal visible space, the horizontal scroll bar has no effect. To
scroll you have to put the caret into the text box and scroll back and
forth using the arrow keys.
3) When dragging the command layer, in the
RecreateItem
the line
elif self.GetPyData(dragItem)[0]['type'] == 'command':
will never take control because for command layers the previous
if self.GetPyData(dragItem)[0]['ctrl']:
will always be true and the dropped control will be painted without the
text box.
4) Besides even if the above elif could execute, the command layer text
box would be painted with
pos=wx.DefaultPosition, size=(250,25)
that in any case is incorrect.
5) Since when the text box is initially created, the visible width is set
relative to the width of the Layer Manager panel, one would expect that
resizing the width of the Layer Manager panel would also resize
accordingly the visible part of the text box, but this does not happen.
BTW, from a basic overview it looks like the layertree.py in the trunk
suffers the same problems.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1239>
