On 14/12/10 16:11, Markus Neteler wrote: > Hi, > > I have some troubles with the SQLite driver with a SELECT statement: > > GRASS 6.4.1svn (patGB1):~> echo 'SELECT cat FROM > MRR1_09_marked_csv_lines_id ' | db.execute > I wonder what the problem could be... s/db.execute/db.select Moritz
