[GRASS-dev] Re: [GRASS GIS] #1239: wxGUI command layer broken and unusable
GRASS GIS trac at osgeo.org
Tue Dec 14 18:44:07 EST 2010
 Reporter:  garu         |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.1
Component:  wxGUI        |     Version:  6.4.0
 Keywords:               |    Platform:  MSWindows XP
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [comment:1 cmbarton]:
 > I wonder if it is time to retire this layer type.
 The command layer is the one layer type which is actually necessary.
 Anything else is just a convenience.
 It must be possible to add layers for arbitrary commands, so that the user
 doesn't have to modify the GUI if they add new d.* commands or scripts.
 > In addition to the errors reported above, are problems in parsing this
 accurately.
 If it's parsing anything, that's a design flaw. Once the command name is
 entered, the parameters should be obtained using the module's parameter
 dialog.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1239#comment:2>
