[GRASS-dev] Re: [GRASS GIS] #1240: wxGUI: attribute manager reports db connection not set while existing
GRASS GIS trac at osgeo.org
Wed Dec 15 11:08:46 EST 2010
 Reporter:  neteler  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  6.4.1
Component:  wxGUI    |     Version:  svn-releasebranch64
 Keywords:           |    Platform:  Linux
      Cpu:  x86-64   |
Comment(by neteler):
 Interestingly, also related modules are affected:
 GRASS 6.4.1svn (patGB1):~ > v.db.addcol
 MRR1_09_marked_csv_lines_id_selected col="count integer"
 ERROR: There is no table connected to this map! Run v.db.connect or
        v.db.addtable first.
 GRASS 6.4.1svn (patGB1):~ > v.db.connect -p
 Vector map <MRR1_09_marked_csv_lines_id_selected at fra_sqlite> is connected
 by:
 layer <1> table <MRR1_09_marked_csv_lines_id_selected> in database
 </home/neteler/grassdata/patGB1/fra_sqlite/sqlite.db> through driver
 <sqlite> with key <cat>
Ticket URL: <http://trac.osgeo.org/grass/ticket/1240#comment:1>
