[GRASS-dev] Re: [GRASS-user] SQL Error using "v.color"
Hamish
hamish_b at yahoo.com
Sun Dec 19 17:35:43 EST 2010
Roy:
> > To follow up on your earlier comment, submitting:
> > v.db.connect -g map=pse layer=1 fs=";"
> > yields:
> > 1/pse;pse;cat;C://test/poverty/sqlite.db;sqlite
> > Does this help?
Hamish:
> yes. for some reason on windows the sqlite table is given a name, and
> that gets reported along with the layer number (1/name;...). So trying
> to match against just the number fails. I wasn't aware of that
> name being set by anything yet, although support for it has been there
> for a long time. (?) shrug, "v.db.connect layer=1 -g -l" should avoid
> the grep now, so just a curiosity.
these scripts will probably also need the -l flag instead of the grep:
d.vect.thematic
v.db.addcol
v.db.addtable
v.db.dropcol
v.db.droptable
v.db.join
v.db.renamecol
v.db.update
v.dissolve
v.out.gpsbabel
v.rast.stats
v.report
and we should check python scripts/libs for anything that uses
v.db.connect too as the parsing could be broken there too.
Hamish
