[GRASS-dev] Re: [GRASS GIS] #1245: v.db.connect parsing
GRASS GIS trac at osgeo.org
Mon Dec 20 22:39:51 EST 2010
 Reporter:  hamish                 |       Owner:  hamish
     Type:  defect                 |      Status:  assigned
 Priority:  major                  |   Milestone:  6.4.1
Component:  Vector                 |     Version:  svn-releasebranch64
 Keywords:  v.db.connect, scripts  |    Platform:  All
      Cpu:  All                    |
Description changed by hamish:
Old description:
> Hi,
> just a placeholder bug report for the records; as reported on the mailing
> list.
> sqlite+v.in.ogr adds a table name to the table number reported by
> v.db.connect -p,-g as "number/name". So if parsing for the table number
> we need to use the -l flag as well to suppress the name.
> the following shell scripts are affected, need to check the python
> scripts/lib for this too.
> v.colors (fixed)
> d.vect.thematic
> v.db.addcol
> v.db.addtable
> v.db.dropcol
> v.db.droptable
> v.db.join
> v.db.renamecol
> v.db.update
> v.dissolve
> v.out.gpsbabel
> v.rast.stats
> v.report
> Hamish
New description:
 list.
 v.db.connect -p,-g as "number/name". So if parsing for the table number we
 v.colors (fixed)
 d.vect.thematic
 v.db.addcol
 v.db.addtable
 v.db.dropcol
 v.db.droptable
 v.db.join
 v.db.renamecol
 v.db.update
 v.dissolve
 v.out.gpsbabel
 v.rast.stats
 v.report
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1245#comment:2>
