[GRASS-dev] [GRASS GIS] #1248: r.thin may be broken
trac at osgeo.org
Tue Dec 21 11:15:55 EST 2010
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.thin | Platform: Unspecified
Cpu: Unspecified |
I recently tried to use r.thin in GRASS 7 (compiled from trunk a few days
ago) and it seems to be behaving oddly. So I tested it against the
Spearfish demo set. I ran r.watershed to generate a stream network
(delete_streams) and then tried to thin it. The network generated by
r.watershed is already down to a single cell in most places; only a few
need thinning. But the r.thin output seems odd. It says it is deleting
thousands of cells each iteration, with the number of cells deleted
dropping by 8 each iteration. After 200 iterations, r.thin says that
thinning is not completed. Looking at results, only a small fraction of
the stream network was actually generated by r.thin. Here is an example of
r.thin output:
r.thin input=delete_streams at PERMANENT output=delete_streams_thinned
File delete_streams at PERMANENT -- 466 rows X 633 columns
Bounding box: l = 2, r = 634, t = 2, b = 467
Pass number 1
Deleted 2194 pixels
Pass number 2
Deleted 2186 pixels
Pass number 3
Deleted 2178 pixels
Pass number 4
Deleted 2170 pixels
Pass number 5
Deleted 618 pixels
Pass number 199
Deleted 610 pixels
Pass number 200
Deleted 602 pixels
Thinning not completed, consider to increase 'iterations' parameter.
Output file 466 rows X 633 columns
Window 466 rows X 633 columns
Ticket URL: <http://trac.osgeo.org/grass/ticket/1248>
