[GRASS-dev] Re: [GRASS GIS] #886: improve module wxGUI tab logic
trac at osgeo.org
Tue Dec 21 15:51:14 EST 2010
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: tabs | Platform: All
Cpu: All |
Comment(by hamish):
Replying to [comment:4 martinl]:
> {{{suppress_required}}} solves this problem.
it mitigates the symptoms of the problem, but does not solve it.
I guess my main complaint is Req=YES being used just to force the
important options on to the front tab for visibility purposes. Even if a
work around exists which lets it not be strictly Required after all.
'd.vect disp=' is an example. These convolutions and tricks strike me as a
strong hint that there's something amiss in our current module UI design,
perhaps because it's born from our programmer's perspective not the user's
perspective.
> I am quite satisfied with "Required" as the first tab.
and yet that last 5% is bugging me.. it's a close fit but not exactly
right.
> Probably we could rename "Optional" to "Others".
I don't really mind either way, but at least "Required"+"Optional" are
matched & not mixing metaphors. Verbally (and so logically to the user) I
would think that "Others" would more match something like "Important". So
as long as there is "Req'd" I'd stick with "Optional", at least it
matches..
perhaps I need to read some more design books to better articulate what I
mean.
ho ho,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/886#comment:5>
