[GRASS-dev] Re: [GRASS GIS] #886: improve module wxGUI tab logic
trac at osgeo.org
Wed Dec 22 13:40:53 EST 2010
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: tabs | Platform: All
Cpu: All |
Comment(by cmbarton):
I agree about using guisection in this way. My point is that there should
not be a hard-coded link between the fist notebook page (tab 1), using the
word "Required" as the name of the tab, and flagging an argument as
required or not. These arrangements should be determined by the module
programmer, but should follow GRASS programming standards.
I agree with Glynn that putting required items up front is a very good
idea. I simply can imagine a case where it might make more sense from the
user perspective to have a required item on another tab.
It would be good if all required items were visually identified in a
consistent way. This is a GUI parsing function. This makes it easy for the
user to see what MUST be filled in.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/886#comment:10>
