[GRASS-dev] [GRASS GIS] #1249: unexpected error from the wxguy using "show attribute table" from the toolbar.
GRASS GIS trac at osgeo.org
Thu Dec 23 09:24:17 EST 2010
toolbar.
 Reporter:  met     |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  normal  |   Milestone:  6.4.1
Component:  wxGUI   |     Version:  svn-releasebranch64
 Keywords:  phyton  |    Platform:  MSWindows XP
      Cpu:  x86-32  |
 from GRASS GIS Layer Manager selecting  "Show attribute table" from
 the toolbar, if database name contains ":"  (like win/dos unit name)
 ,the program crashes.
 We now report an example with the command db.connect in which the cause of
 the error discussed shows itself.
 --------example---------
 db.connect -p
 driver:sqlite
 database:D:\GIS_db\websir\parma\settembre.db
 schema:
 group:
 v.db.connect -p map=settembre at parma
 Vector map <settembre at parma> is connected by:
 layer <2> table <NODES> in database <D:\GIS_db\websir\parma\settembre.db>
 through driver <sqlite> with key <cat>
 layer <1> table <LINKS> in database <D:\GIS_db\websir\parma\settembre.db>
 "D:\GRASSS\GRASS-64-SVN\etc\wxpython\gui_modules\dbm.py",
 line 2353, in __init__
 item, value = line.split(':')
 ValueError
 too many values to unpack
  command type "connect" contains
 'driver:sqlite\ndatabase:D:\\GIS_db\\websir\\parma\\settembre.db\nschema:\ngroup:\n'
 <type 'str'>
 and when line contains 'database:D:\\GIS_db\\websir\\parma\\settembre.db'
 line.split(':') restitutes 3 values instead of 2!!
 solution:
 in .\etc\wxpython\gui_modules\dbm.py line 2353 substitute
 with
 item, value = line.split(':',1)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1249>
