[GRASS-dev] Re: [GRASS GIS] #1251: tweaking new feature in file
selection drop-down of layer manager
trac at osgeo.org
Fri Dec 24 12:41:37 EST 2010
#1251: tweaking new feature in file selection drop-down of layer manager
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Changes (by cmbarton):
* type: enhancement => defect
Comment:
Changing this to a bug. I found out that once a layer is displayed, you
can no longer change the map that is displayed in that layer. That is,
even if you delete the name of the map and pick a new one from the now
visible list, the new map selected is not displayed. The new filter
prevents any other map from being displayed.
This feature needs to be disabled until it is working correctly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:1>
