[GRASS-dev] Re: [GRASS GIS] #1251: tweaking new feature in file
selection drop-down of layer manager
trac at osgeo.org
Sat Dec 25 08:37:09 EST 2010
#1251: tweaking new feature in file selection drop-down of layer manager
Reporter: cmbarton | Owner: martinl
Type: defect | Status: assigned
Priority: critical | Milestone: 6.4.1
Component: wxGUI | Version: svn-trunk
Keywords: map selection | Platform: Unspecified
Cpu: Unspecified |
Comment(by martinl):
Replying to [ticket:1251 cmbarton]:
> I originally thought this was a weird bug but it seems to be a new
feature that needs to be tweaked somewhat. Apparently, a new filtering
function has been added to the file selection drop
Filtering map names has been implemented in r44638, besides
collapsing/expending mapset by left/right arrow. It was designed as the
first step to make selection widget usable for long list of maps.
> down to make it easier to find files in long lists within a mapset. This
is a good thing in general. But the filter is on all the time with no
visual indication that it is active, leading a user to think that his/her
files have disappeared when editing layer properties.
In r44715 is filtering disabled when item is found (on full match). The
widget should indicate that it offers only selection of items.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:5>
