[GRASS-dev] Re: [GRASS GIS] #965: Location wizard: doesn't create
MYNAME
trac at osgeo.org
Wed Dec 29 08:45:41 EST 2010
#965: Location wizard: doesn't create MYNAME
Reporter: hamish | Owner: martinl
Type: defect | Status: reopened
Priority: normal | Milestone: 6.4.1
Component: wxGUI | Version: svn-releasebranch64
Resolution: | Keywords: location wizard
Platform: All | Cpu: All
Comment(by martinl):
Replying to [comment:4 hamish]:
> perhaps wrongly applied, but G_myname() is using GNAME_MAX for the max
length (256 chars in gis.h) of the description.
yes, GNAME_MAX could be replaced by GPATH_MAX (or new GTITLE_MAX) to
enlarge the buffer.
> So besides having the newlines removed it should be cut at char 255-1
for the null terminator(?).
see changes in location wizard r44754
> Or better: can python access the #defined values in the C include files
directly as swig could?
Could be accessed using ctypes. Currently wxGUI is not using ctypes
(except of 3D view mode).
Ticket URL: <https://trac.osgeo.org/grass/ticket/965#comment:7>
