[GRASS-dev] Re: [GRASS GIS] #885: WinGrass: displaying r.external-linked raster data not working
GRASS GIS trac at osgeo.org
Tue Feb 2 14:37:59 EST 2010
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Display          |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  r.external, WinGrass, osgeo4w
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by hellik):
 Replying to [comment:26 glynn]:
 > Regarding my comments in comment:1 :
 > > OTOH, it may be better to simply omit the r.external support from 6.5;
 it's very out of date (it was back-ported shortly after the first draft of
 the code was added to 7.0, and hasn't been updated since).
 > It turns out that the read support hasn't actually changed
 significantly, and back-porting the write support isn't really an option.
 fresh grass65svn (r40780), self compiled with default configure options
 in /mswindows/osgeo4w/package.sh
 =>"d.rast -o map=testRlink at user1" is working and the linked testRlink-data
 is displayed in the wx-gui!
 what is the difference between Grass64 and Grass65 in this case?
 maybe anyone else can test the nightly builts of Grass64 and Grass65 for
 this issue?
 r.info map=testRlink at user1
 Kategorie Unterstützung für [testRlink at user1] im Mapset [user1] missing
  | Layer:    testRlink at user1                Date: Tue Feb 02 20:23:46 2010
  | Mapset:   user1                          Login of Creator: syringia
  | DataBase: C:\gisdata\grassdata
  | Title:    ?? ( testRlink )
  | Timestamp: none
  |   Type of Map:  raster               Number of Categories: ??
  |   Data Type:    FCELL
  |   Rows:         1350
  |   Columns:      1500
  |   Total Cells:  2025000
  |        Projection: Lambert Conformal Conic
  |            N:     228500    S:     215000   Res:    10
  |            E:     645000    W:     630000   Res:    10
  |   Range of data:    min = 55.98819  max = 155.9353
  |   Data Description:
  |    generated by r.external
  |   Comments:
  |    r.external input="C:\wd\mg\elev_export.tif" output="testRlink"
 band=1   |
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/885#comment:27>
