[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
trac at osgeo.org
Tue Feb 2 17:43:24 EST 2010
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: NVIZ | Version: svn-releasebranch64
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: x86-32
Comment (by hellik):
Replying to [ticket:902 hamish]:
> Hi,
> with the latest WinGrass nightly build installer (r40766), installed in
C:\Program Files\, nviz (tcl) fails to start.
> even from the MSys command prompt there error is:
> GRASS 6.4> nviz --help
> Sorry <Files/GRASS-64-SNV/etc/nviz2.2/script/nviz2.2_script> is not a
valid option
> Description
> nviz - Visualization and animation tool for GRASS data.
> Keywords:
> Usage:
> If I reset $GISBASE beforehand to get rid of the space, it works:
> GRASS 6.4> export GISBASE=/C/PROGRA~1/GRASS-64-SVN
> I assume we could hardcode that conversion as part of the GRASS-
Installer.nsi (as follows), but it would be good to fix it properly.
> ;Get the short form of the install path (to allow for paths with spaces)
> VAR /GLOBAL INST_DIR_SHORT
> GetFullPathName /SHORT $INST_DIR_SHORT $INSTALL_DIR
> also just to note that the nightly build process still is shipping
msys/grass70.* files and does not use a copy of msys.bat with all paths
"quoted" which causes (non-fatal) errors in the startup.
> Hamish
i can confirm this on self compiled Wingrass64+65-installers installed in
C:\Program Files\, even if i use the msys.bat from ticket #629 with all
paths "quoted".
but nviz is working if I use the self compiled grass64+65 living in
c:\osgeo\apps\grass.
Helmut
p.s. i've integrated the msys from ticket #629 (with quoted paths) locally
into GRASS-Installer.nsi for Grass65. should i apply this for testing in
Grass65svn? I've tested it a little bit locally and it seems to work
(beside the nviz-issue).
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:1>
