[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
trac at osgeo.org
Tue Feb 2 21:21:43 EST 2010
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: NVIZ | Version: svn-trunk
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:2 glynn]:
> Or simpler still, change Ngetargs to return `argv[0]` separately (and
just ignore `argv[1]`), and change parse_command() to match.
I've applied this solution to trunk in r40784.
And also eliminated a C99/gcc-ism: C89 requires the dimensions of an array
declaration to be a compile-time constant, so:
char *argv2[argc - 1];
isn't valid.
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:3>
