[GRASS-dev] Re: [GRASS GIS] #903: Category color in r.grow
trac at osgeo.org
Wed Feb 3 01:13:11 EST 2010
Reporter: clerici | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: Linux | Cpu: Unspecified
Comment (by hamish):
What it does is copy the color table from the input map and applies it to
the output map.
When you use the new= option (or old=) with a value which is out of range
of the old color table, the new value will probably be undefined in the
old color table.
With GRASS 6.2 if you run "`r.colors railroads.grown1 color=random`" you
will see that it did grow, just that the out-of-range color was previously
coming out as white so you didn't see it.
With GRASS 6.3.0 and newer instead of undefined colors going to white it
repeats the color table. If you try with the "roads" raster map and
new=16, you can see the effect pretty well with d.legend.
I guess if those options are specified we could explicitly set old= to
yellow and new= to red (similar to how r.buffer does) to at least set them
to something.
Note if the input map's color table has a "default" (*) color defined in
it this be will be used for undefined values instead of empties being
filled by the cycling effect.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/903#comment:1>
