[GRASS-dev] Re: [GRASS-user] Set language in Linux
Gilbert Ferrara
gilbertferrara1974 at gmail.com
Wed Feb 3 11:20:40 EST 2010
Greetings Markus
It worked :)
Thank you
I'm getting an error, that before I was getting:
GRASS 6.4.0svn (North-Carolina):~ >
(process:4282): Gdk-WARNING **: locale not supported by C library
(process:4282): Gtk-WARNING **: Locale not supported by C library.
Using the fallback 'C' locale.
But it works at least for wxpython translations. Grassmods no.
Regarding .UTF-8 and without .UTF-8, it was the same. I thought that this
error had something to do wuth UTF-8 but no.
Ok thanks
Best regards
Gilbert
On Wed, Feb 3, 2010 at 3:37 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi Gilbert,
> On Wed, Feb 3, 2010 at 3:39 PM, Gilbert Ferrara
> <gilbertferrara1974 at gmail.com> wrote:
> > Hello Markus
> > You suggestion is to maintain grass64 file and create those two right?
> Yes, I would not touch the original grass64 file.
> > At the end of each one of them it calls grass64 by grass64 "$@" right?
> Right. With "$@" you can pass parameters to the original start script.
> > But if I was running grass64 -wxpython, if I run grass64eng -wxpython,
> the
> > "-wxpython" is still parsed?
> Yes, because of the "$@" parameter.
> Did you try? :)
> > es_ES.UTF-8 ? How can I know if this is applicable?
> Try and error.... Either without or with .UTF-8, depends on the
> distribution
> you use.
> > Thank you
> > When I tried, I will reply to the grass mailing list
> Perfect.
> cheers
> Markus
> > Thank you merci
> > Gilbert
> > On Wed, Feb 3, 2010 at 2:31 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> >> On Wed, Feb 3, 2010 at 1:35 PM, Gilbert Ferrara
> >> > I just want to provide GRASS64 in two languages and without the user
> has
> >> > to
> >> > define lang in the bash_profiles.
> >> > My idea was to create 2 files: grass64eng and grass64sp each one with
> >> > different language sets. So the user would have only to select the
> >> > adequate
> >> > file.
> >> I would create
> >> grass64eng
> >> export LANG=en_US
> >> export LANGUAGE=en_US
> >> export LC_MESSAGES=en_US
> >> grass64 "$@"
> >> grass64sp
> >> export LANG=es_ES
> >> export LANGUAGE=es_ES
> >> export LC_MESSAGES=es_ES
> >> grass64 "$@"
> >> (or, if applies es_ES.UTF-8 instead of es_ES).
> >> Hope this helps,
> >> Markus
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100203/11ccd9d4/attachment-0001.html
