[GRASS-dev] Building winGRASS: packager.sh on MingW calls MS-VS's
dumpbin tool
Colin (Nielsen) Wren
colin.nielsen at gmail.com
Wed Feb 3 14:34:04 EST 2010
For the record VC is required to build some parts of the grass osgeo4w
packages. jef included this in the script so that others could update
the packages for the osgeo4w installer.
If I remember correctly, jef and I both tried to get everything made
in MinGW but a few things wouldn't work so VC had to be used in the
end.
hellik's update to comment out those lines is perfect but we shouldn't
remove them entirely.
-Colin
On 19 January 2010 01:52, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> when following
> https://trac.osgeo.org/grass/wiki/CompileOnWindows#CompilingandInstallingGRASS6.4.0
> (i.e., running ./mswindows/osgeo4w/package.sh with MinGW):
> GRASS is compiled, HTML manual is built etc. Then it installs (tar xBf ...),
> (man/ is skipped), then "STARTING cleanup", and then
> "STARTING building vc libraries"
> Then it fails with
> mswindows/osgeo4w/mklibs.sh: dumpbin: command not found
> I wonder why it tries to use VC stuff here. Is it for the QGIS interface?
> If so, what's the trick here? If Visual Studio is needed, shouldn't it be
> mentioned in the install instructions?
> confused,
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
