[GRASS-dev] grass7 build on osx snow leopard
Wed Feb 3 22:39:39 EST 2010
Massimo Di Stefano wrote:
> Tring to build grass7 on snow leopard
> i had a long list of errors, here the coplete build log :
> http://www.geofemengineering.it/data/grass7_log.txt
As is normally the case, the first error is what's relevant:
Undefined symbols:
  "_iconv", referenced from:
      _print_escaped_for_xml in parser_interface.o
  "_iconv_close", referenced from:
  "_iconv_open", referenced from:
make[3]: *** [/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.2.0/lib/libgrass_gis.7.0.svn.dylib] Error 1
Obviously, if lib/gis fails to compile, the rest of GRASS is toast.
Try this:
Index: include/Make/Grass.make
--- include/Make/Grass.make	(revision 40803)
+++ include/Make/Grass.make	(working copy)
@@ -190,7 +190,7 @@
 DSPFDEPS         = $(GISLIB)
 FORMDEPS         = $(DBMILIB) $(GISLIB)
 G3DDEPS          = $(RASTERLIB) $(GISLIB) $(XDRLIB)
-GISDEPS          = $(DATETIMELIB) $(ZLIBLIBPATH) $(ZLIB) $(INTLLIB) $(REGEXLIBPATH) $(REGEXLIB) $(PTHREADLIBPATH) $(PTHREADLIB) $(MATHLIB)
+GISDEPS          = $(DATETIMELIB) $(ZLIBLIBPATH) $(ZLIB) $(INTLLIB) $(REGEXLIBPATH) $(REGEXLIB) $(ICONVLIB) $(PTHREADLIBPATH) $(PTHREADLIB) $(MATHLIB)
 GMATHDEPS        = $(GISLIB) $(FFTWLIB) $(LAPACKLIB) $(BLASLIB) $(CCMATHLIB)
 GPDEDEPS         = $(G3DLIB) $(RASTERLIB) $(GISLIB) $(GMATHLIB) $(MATHLIB)
 GPROJDEPS        = $(GISLIB) $(GDALLIBS) $(PROJLIB) $(MATHLIB)
