[GRASS-dev] scripts don't launch GUI from the msys command line in
winGRASS
Helmut Kudrnovsky
hellik at web.de
Thu Feb 4 16:38:52 EST 2010
>-----Ursprüngliche Nachricht-----
>Von: "Glynn Clements"
>Gesendet: 04.02.10 21:16:59
>Helmut Kudrnovsky wrote:
>> >So far, I've only seen this in Vista and am wondering if anyone else has seen it. Using the nightly build from 2 February.
>> >From the command line, type the name of a script, like r.blend, without arguments
>> >Instead of the GUI popping up, there is an error complaining about the lack of arguments.
>> >It's like g.parser is not being invoked.
>> i can confirm this changed behaviour, typing a command without arguments and no GUI popping up.
>> tested on WinVista32 with self compiled Grass64 and Grass65
>Note that if GRASS_GUI is tcltk, it won't work, due to G_popen() not
>working at all on Windows (execl() works like on Unix, i.e. it doesn't
>return if it succeeds; but unlike Unix, Windows doesn't have fork()).
>Using the new G_popen() from 7.0 is one option.
>Glynn Clements <glynn at gclements.plus.com>
I've tried this from the msys-shell, for example g.region, r.blend, ..., and if I remember correctly, this worked by popping up the gui until a week ago or so.
here is the error message:
"GRASS 6.4> r.blend
Fehler: Benötigter Parameter <first> ist nicht gesetzt:
(Name der ersten Rasterkarte für die Mischung.).
error: needed parameter <first> not set
Fehler: Benötigter Parameter <second> ist nicht gesetzt:
(Name der zweiten Rasterkarte für die Mischung.).
error: needed parameter <second> not set
Fehler: Benötigter Parameter <output> ist nicht gesetzt:
(Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung.).
error: needed parameter <output> not set"
but it's working from the wx-gui-command-line, from the tcltk-command-line (by the buttons "run in background","run GUI", and "run in DOS-box").
tested here on another WinVista32-box withthe nightly build WinGRASS-6.4.SVN-r40792-1-Setup.exe
Helmut
______________________________________________________
GRATIS für alle WEB.DE-Nutzer: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://movieflat.web.de
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20100204/ac0d76b7/smime-0001.bin
