[GRASS-dev] [GRASS GIS] #910: wxgui: fails with make -j
GRASS GIS trac at osgeo.org
Fri Feb 5 04:03:21 EST 2010
 Reporter:  hamish           |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  7.0.0
Component:  Compiling        |     Version:  svn-trunk
 Keywords:  wxgui, Makefile  |    Platform:  Linux
      Cpu:  x86-64           |
 latest trunk on debian/stable with "make -j 8" on a amd64 quad-core.
 gui/wxpython/ fails with:
 make[2]: Entering directory `/usr/local/src/grass/svn/trunk/gui'
 make -C icons || echo /usr/local/src/grass/svn/trunk/gui/icons >>
 /usr/local/src/grass/svn/trunk/error.log
 make -C images || echo /usr/local/src/grass/svn/trunk/gui/images >>
 make -C scripts || echo /usr/local/src/grass/svn/trunk/gui/scripts >>
 make -C xml || echo /usr/local/src/grass/svn/trunk/gui/xml >>
 make -C wxpython || echo /usr/local/src/grass/svn/trunk/gui/wxpython >>
 make[3]: Entering directory `/usr/local/src/grass/svn/trunk/gui/images'
 make /usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-
 gnu/etc/gui/images/startup_banner.png
 make[3]: Entering directory `/usr/local/src/grass/svn/trunk/gui/xml'
 /usr/bin/install -c  -m 644 grass-interface.dtd
 /usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-gnu/etc/grass-
 interface.dtd
 make[3]: Leaving directory `/usr/local/src/grass/svn/trunk/gui/xml'
 make[3]: Entering directory `/usr/local/src/grass/svn/trunk/gui/icons'
 mkdir -p /usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-
 gnu/etc/gui/icons
 gnu/etc/gui/icons/grass
 gnu/etc/gui/icons/grass/vdigit
 gnu/etc/gui/icons/silk
 make[4]: Entering directory `/usr/local/src/grass/svn/trunk/gui/images'
 gnu/etc/gui/images
 gnu/etc/gui/icons/grass2
 /usr/bin/install -c  -m 644 startup_banner.png
 make[3]: Entering directory `/usr/local/src/grass/svn/trunk/gui/wxpython'
 gnu/etc/wxpython
 make[4]: Leaving directory `/usr/local/src/grass/svn/trunk/gui/images'
 make[3]: Leaving directory `/usr/local/src/grass/svn/trunk/gui/images'
 make[3]: Entering directory `/usr/local/src/grass/svn/trunk/gui/scripts'
 /usr/bin/install -c  g.change.gui.py /usr/local/src/grass/svn/trunk/dist.
 x86_64-unknown-linux-gnu/etc/gui/scripts/g.change.gui.py
 /usr/bin/install -c  v.type_wrapper.py
 gnu/etc/gui/scripts/v.type_wrapper.py
 make[3]: Leaving directory `/usr/local/src/grass/svn/trunk/gui/scripts'
 GISBASE="/usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-gnu" \
         python gui_modules/menudata.py > menustrings.py
   File "gui_modules/menudata.py", line 208, in <module>
     data = Data()
   File "gui_modules/menudata.py", line 45, in __init__
     self.tree = etree.parse(filename)
   File "/usr/lib/python2.5/xml/etree/ElementTree.py", line 862, in parse
     tree.parse(source, parser)
   File "/usr/lib/python2.5/xml/etree/ElementTree.py", line 579, in parse
     source = open(source, "rb")
 IOError: [Errno 2] No such file or directory:
 '/usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-
 gnu/etc/wxpython/xml/menudata.xml'
 make[3]: *** [menustrings.py] Error 1
 make[3]: Leaving directory `/usr/local/src/grass/svn/trunk/gui/wxpython'
 ... suspected Makefile dep mis-order..
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/910>
