[GRASS-dev] [GRASS GIS] #913: (windows) r.external does not work in
both osgeo4w and standalone packages
trac at osgeo.org
Sun Feb 7 12:20:34 EST 2010
#913: (windows) r.external does not work in both osgeo4w and standalone packages
Reporter: lutra | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Keywords: | Platform: MSWindows XP
Cpu: x86-32 |
When using r.external under windows trough qgis, the module finishes
correctly, but then when adding the raster to canvas the program returns
the following warnings
Cannot draw raster
Cannot start module
command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.d.rast.exe
map=land at demo
window=-7.1176e+06,1.32961e+06,4.89704e+06,7.80968e+06,1184,639<br><br>
GRASS_INFO_ERROR(2864,1): Unable to locate symbol <GDALAllRegister>
GRASS_INFO_END(2864,1)
and
Cannot query raster
Cannot start module
command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.g.info.exe
info=query rast=land at demo coor=-3.89397e+06,5.61803e+06<br><br>
GRASS_INFO_ERROR(1596,1): Unable to locate symbol <GDALAllRegister>
GRASS_INFO_END(1596,1)
and the raster appears all gray.
The same kind of messages are returned if using osgeo4w GRASS (not trough
QGIS) or the standalone installer
Under linux it seems to work all fine.
Ticket URL: <https://trac.osgeo.org/grass/ticket/913>
