[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
GRASS GIS trac at osgeo.org
Mon Feb 8 03:08:38 EST 2010
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  NVIZ      |     Version:  svn-trunk
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by hamish):
 Ok, now it seems to work ok from the 6.5 command line and GUIs. So
 backported to 6.4.
 but still a weird problem in trunk:
  * G7> nviz --ui
  * (module option gui opens)
  * select raster elevation: elevation.dem at PERMANENT
  * [Run]
  * a window flashes open then closes again and this is written to the
 module GUI output tab:
 (Mon Feb  8 21:00:20 2010)
 /usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-
 gnu/etc/nviz2.2/nviz elevation=elevation.dem at PERMANENT
 Error in startup script: couldn't read file
 "elevation=elevation.dem at PERMANENT": no such file or
 directory
 (Mon Feb  8 21:00:20 2010) Command finished (0 sec)
 If I try again, but with the --verbose flag turned on, the Please wait..
 and NVIZ wish windows open (and stay open); the authors text is written to
 the output tab ($Id$ seems broken); then it locks up after:
 The papers are available at
 http://www2.gis.uiuc.edu:2280/modviz/
 Loading raster map <elevation.dem at PERMANENT>...
 Translating colors from raster map <elevation.dem at PERMANENT>...
 Pressing the [Abort command] button writes the inconsistent stage warning
 (which isn't really needed here [s/stage/state/?]) and stops it.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:14>
