[GRASS-dev] Re: [GRASS GIS] #908: No Font Definition File,
windows xp
trac at osgeo.org
Mon Feb 8 18:14:13 EST 2010
#908: No Font Definition File, windows xp
Reporter: voncasec | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Installation | Version: svn-releasebranch64
Resolution: | Keywords: v.label.sa, g.mkfontcap, wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment (by hellik):
Replying to [comment:9 glynn]:
> Replying to [comment:8 glynn]:
> > AFAICT, the simplest fix is to add:
> G_set_gisrc_mode(G_GISRC_MODE_MEMORY);
> > to `G_no_gisinit()`.
> Oops. It took me all of two minutes to realise that isn't going to work
(it breaks >g.proj and g.gisenv). I've moved the code into g.mkfontcap and
g.dirseps in r40856 >(7.0) and r40857 (6.5).
what does this mean for running g.mkfontcap outside a Grass-session (and
accordingly for the NSIS-installer)? which parameters have to be set for
working g.mkfontcap outside a Grass-session?
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/908#comment:10>
