[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
GRASS GIS trac at osgeo.org
Mon Feb 8 19:01:56 EST 2010
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  NVIZ      |     Version:  svn-trunk
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by glynn):
 Replying to [comment:16 glynn]:
 > I think that it might be better to change the startup, moving the top of
 parse_command() (everything up to and including the G_parser() call) into
 main(), so that it's a normal "GRASS module" main(). If G_parser()
 indicates normal operation (i.e. not --help, --ui, etc), we call Tk_Main()
 with "fabricated" argc and argv (i.e. insert the "-f nviz2.2_script"). For
 --help, --ui etc, Tcl/Tk never gets involved.
 > This doesn't allow the nviz binary to be used to run arbitrary scripts,
 but I'm not so sure that works anyhow.
 I've done this for 7.0 in r40879. The nviz binary is installed into
 $GISBASE/bin; the script and batch file aren't used. If argv[1] is '-f',
 it behaves like "wish", otherwise it behaves like a GRASS module:
 G_gisinit(), G_parser(), then calls Tk_Main() with argv = {"nviz", "-f",
 ".../nviz2.2_script", NULL}. It appears to do the right thing for all
 cases (nviz, nviz -q, nviz --ui (then "Run"), nviz elevation.dem), at
 least on Linux (compiling on Windows takes a while).
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:17>
