[GRASS-dev] Re: [GRASS GIS] #916: GRASS 7: make install fails with
--prefix
trac at osgeo.org
Mon Feb 8 21:38:07 EST 2010
#916: GRASS 7: make install fails with --prefix
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: default | Version: svn-trunk
Resolution: | Keywords:
Platform: Linux | Cpu: Unspecified
Comment (by glynn):
Replying to [ticket:916 neteler]:
> a series of bugs appear which indicate that the --prefix path
> was not properly propagated. The problem might be that the
> Makefile no longer has an "install" target (guessing).
The "install" target is in Install.make, which is "include"d from the top-
level Makefile.
The problem is that r40491 removed the "BINDIR=${UNIX_BIN}" with the
intention of just using $(UNIX_BIN) instead, but didn't follow through.
Fixed in r40882.
Ticket URL: <http://trac.osgeo.org/grass/ticket/916#comment:3>
