[GRASS-dev] r.out.gdal -f flag clarification
Markus Metz markus.metz.giswork at googlemail.com
Tue Feb 9 09:21:43 EST 2010
Patton, Eric wrote:
> Hi,
> I trying to decipher the meaning of the description of the r.out.gdal
> –f flag. Currently, it reads:
> “Force raster export also if data loss may occur”
The long description would be that the -f flag does not have any effect
if no data loss occurs. Only if the export settings would result in
actual data loss, the -f flag has an effect and allows for the creation
of a raster that is not an exact (as exact as possible given the chosen
export format) representation of the raster map to be exported using the
current computational region. Without the -f flag, if any of the tests
is not passed, an error message is issued describing the problem and the
module exits without exporting. The -f flag allows to export a raster
even if some of the tests are not passed and warnings are issued instead
of errors.
> I take it it should read “Force raster export (note: data loss may occur)”
That sounds a bit like the -f flag would cause the module to export a
raster somehow differently than without the -f flag which is not the
case, the -f flag only overrides tests for data loss. IOW, if a raster
could only be exported with the -f flag set, data loss will have
occurred, not may have occurred.
The idea was to run r.out.gdal first without the -f flag, if it
complains, change export settings or override with -f flag.
I guess the documentation as well as the warning and error messages
could do with some improvement/clarification?
Markus M
