re [GRASS-dev] g.proj -p - units is : meters or metres ?
Glynn Clements
glynn at gclements.plus.com
Tue Feb 9 19:13:46 EST 2010
Markus Neteler wrote:
> > Note that, by default, the Mailman list management software doesn't
> > send a copy of a message to any user who is listed in the To, CC, etc
> > headers. If you don't receive the direct copy due to e.g. anti-spam
> > filters, then you won't receive a copy at all.
> > I recommend disabling this feature in your mailmain preferences:
> > http://lists.osgeo.org/mailman/options/grass-dev/
> > I've asked for this "feature" to be disabled by default, but that
> > hasn't happened.
> I was not aware of this request (or forgot).
> If there are no objections, I guess that we can change the Mailman settings.
> Not sure though, if that propagates to all users or if settings are
> kept (likely).
Changing the default won't affect existing users. Personally, I'd be
inclined to change existing users' settings as well; they can always
change them back if they actually want it enabled. I suspect that most
people have it enabled simply because they don't know about it.
