[GRASS-dev] Reverting svn submission
Tue Feb 9 23:05:40 EST 2010
Patton, Eric wrote:
> I'm trying to revert r40901, an update to the description of the -f flag in trunk/raster/r.out.gdal/main.c:
> svn merge -c -40901 https://svn.osgeo.org/grass/grass/trunk/
> but I think I neglected to append the extra directories
> "raster/r.out.gdal/main.c" to the end of the above command; can
> someone verify if I screwed something up?
> What is the correct revert command?
I think that the above is correct. The change only affected that one
file, so reverting it will only affect one file.
Note that "svn merge" only affects the working copy; you still need to
use "svn commit" to push the change the repository.
