[GRASS-dev] Re: [GRASS GIS] #317: WinGRASS MSYS Console doesn't run
correctly
trac at osgeo.org
Wed Feb 10 16:49:48 EST 2010
#317: WinGRASS MSYS Console doesn't run correctly
Reporter: gislab | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords: msys console
Platform: MSWindows XP | Cpu: x86-32
Old description:
> 1. Install GRASS in C:\GRASS
> 2. Check C:\GRASS\msys\home\, in this folder C\Documents and
> Settings\MYNAME is created during install, where grass63 is sitting.
> 3. Run Start\Programs\GRASS\GRASS MSYS Console
> 4. Check C:\Gis\GRASS\msys\home\ again, now in this folder MYNAME
> (lowercase) folder is created, without grass63 file in it.
> Needless to say, that even if I move grass63 from the folder made
> right after install
> "C:\GRASS\msys\home\C\Documents and Settings\MYNAME"
> to the one created on first run of MSYS
> "C:\GRASS\msys\home\MYNAME"
> GRASS GUI starts with error messages, grass63 -text doesn't start at all,
> producing "Redirection is not supported" message.
> Removing .grassrc6 from C:\GRASS\msys\home\C\Documents and
> Settings\USERNAME\
> and .grassrc6 from C:\Documents and Settings\USERNAME\
> doesn't help.
> The problem was replicated on at least 4 more machines by other
> people under the same operating system and grass version.
> http://lists.osgeo.org/pipermail/grass-windows/2008-September/001502.html
New description:
right after install
Settings\USERNAME\
doesn't help.
Comment (by neteler):
Recent GRASS 6.4 should no longer have (much?) problems with white space
in the install path. Please retry with a new winGRASS version from
http://josef.fsv.cvut.cz/wingrass/grass64/
Ticket URL: <http://trac.osgeo.org/grass/ticket/317#comment:2>
