[GRASS-dev] Re: [GRASS GIS] #927: Crash on starting GRASS 6.4 on a Mac OS Snow Leopard
GRASS GIS trac at osgeo.org
Fri Feb 12 20:44:38 EST 2010
  Reporter:  dormerod     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by kyngchaos):
 Did you build from source or install a binary?
 If you are using the binary from kyngchaos (me), make sure you install the
 correct version for your system - the Snow Leopard (10.6) version will not
 run on Leopard (10.5).
Ticket URL: <http://trac.osgeo.org/grass/ticket/927#comment:1>
