[GRASS-dev] Re: [GRASS GIS] #914: Add multi-channel "import" to
r.external (as in r.in.gdal)
trac at osgeo.org
Fri Feb 12 23:59:02 EST 2010
#914: Add multi-channel "import" to r.external (as in r.in.gdal)
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 6.5.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:2 neteler]:
> Replying to [comment:1 glynn]:
> > Replying to [ticket:914 neteler]:
> > > Currently, r.external "imports" only the first channel, not all
> > > available channels as r.in.gdal does:
> > > The behaviour of r.in.gdal is more user-friendly, could r.external
be improved?
> > Try the attached patch (untested).
> As always, it works out of the box :) Also tested with appropriate
modifications in 6.4.
Committed to trunk in r40961.
Ticket URL: <http://trac.osgeo.org/grass/ticket/914#comment:3>
