[GRASS-dev] [GRASS GIS] #929: g.transform: dump coeffs and
transform sparse points
trac at osgeo.org
Sat Feb 13 11:14:15 EST 2010
#929: g.transform: dump coeffs and transform sparse points
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Keywords: g.transform | Platform: All
Cpu: All |
the attached patch adds a new flag to dump transform coeffs, transform
arbitrary input coords to the other coord system, and a adds a flag to
tell it to do these things in reverse.
it also fixes a little `continue` bug if you selected format="".
based on Glynn's tips on the -dev ML.
http://thread.gmane.org/gmane.comp.gis.grass.devel/38099
I'm not decided what to do about reading from stdin. I suspect I'll have
to drop the east_north=x1,y1,x2,y2,xn,yn,... option in favor of an input
file containing points to be transformed because the parser insists on two
values, and "-,-" if given is read as -0,-0. Well, I guess I could have
strcmp() test for "-,-" but it's a bit silly.
I'd rater not add another flag to direct the input.
any ideas?
FIXME: if using the reverse flag check the TARGET location's
G_projection() type and use it for G_scan_easting() instead of the current
location's type.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/929>
