[GRASS-dev] [GRASS GIS] #930: Wingrass7 - compiling errors
GRASS GIS trac at osgeo.org
Sat Feb 13 16:46:34 EST 2010
 Reporter:  hellik            |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  Compiling         |     Version:  svn-trunk
 Keywords:  wingrass, grass7  |    Platform:  MSWindows Vista
      Cpu:  Unspecified       |
 compiling grass_trunk (grass7) on WinVista32 in the osgeo4w-stack, there
 are errors in a few modules.
 a few errors with ''patch'' in the module-name, so maybe again an issue
 with the UAC on WinVista? but I've this never seen in compiling grass64 or
 grass65
 Errors in:
 /c/osgeo4w/usr/src/grass_trunk/lib/vector/diglib
 $ make
 if [ "" != "" -a -f "".html ] ; then make html ; fi
 ==============TEST=============
 make test
 make[1]: Entering directory
 `/c/osgeo4w/usr/src/grass_trunk/lib/vector/diglib'
 diff OBJ.i686-pc-mingw32/test.tmp test64.ok
 Files OBJ.i686-pc-mingw32/test.tmp and test64.ok differ
 make[1]: *** [test] Error 2
 make[1]: Leaving directory
 make: *** [default] Error 2
 /c/osgeo4w/usr/src/grass_trunk/raster/r.li/r.li.patchdensity
 $ make
 if [ "/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/bin/r.li.patchdensity.exe" != "" ] ; then
 GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/demolocation/.grassrc70
 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32
 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH"
 PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.
 i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/windows/system32:/c/windows:/c/windows/System32/Wbem:/c/Program
 Files/ATI Technologies/ATI.ACE/Core-Static:/c/Program
 Files/ActivIdentity/ActivClient/:/c/Program Files/Hewlett-
 Packard/IAM/bin:/c/Program Files/Common Files/Roxio
 Shared/DLLShared/:/c/Program Files/Common Files/Roxio
 Shared/10.0/DLLShared/:/c/windows/System32/WindowsPowerShell/v1.0/:/c/Program
 Files/TortoiseSVN/bin:/c/Program Files/QuickTime/QTSystem/:/bin" LC_ALL=C
 mingw32/bin/r.li.patchdensity.exe --html-description < /dev/null | grep -v
 '</body>\|</html>' > r.li.patchdensity.tmp.html ; fi
 /bin/sh: /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/bin/r.li.patchdensity.exe: Bad file number
 make: *** [r.li.patchdensity.tmp.html] Error 1
 rm r.li.patchdensity.tmp.html
 /c/osgeo4w/usr/src/grass_trunk/raster/r.li/r.li.patchnum
 $ make
 mingw32/bin/r.li.patchnum.exe" != "" ] ; then
 /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin/r.li.patchnum.exe
 --html-description < /dev/null | grep -v '</body>\|</html>' >
 r.li.patchnum.tmp.html ; fi
 rm r.li.patchnum.tmp.html
 mingw32/bin/r.li.patchnum.exe: Bad file number
 make: *** [r.li.patchnum.tmp.html] Error 1
 /c/osgeo4w/usr/src/grass_trunk/raster/r.patch
 $ make
 if [ "/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin/r.patch.exe"
 != "" ] ; then GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 r.patch.tmp.html ; fi
 rm r.patch.tmp.html
 mingw32/bin/r.patch.exe: Bad file number
 make: *** [r.patch.tmp.html] Error 1
 /c/osgeo4w/usr/src/grass_trunk/vector/v.patch
 $ make
 if [ "/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin/v.patch.exe"
 v.patch.tmp.html ; fi
 rm v.patch.tmp.html
 mingw32/bin/v.patch.exe: Bad file number
 make: *** [v.patch.tmp.html] Error 1
 /c/osgeo4w/usr/src/grass_trunk/gem
 gcc -L/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib
 -L/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib -Wl,--export-
 dynamic,--enable-runtime-pseudo-reloc  -L/c/OSGeo4W/apps/gdal-16/lib
 -L/c/OSGeo4W/lib    -o /c/osgeo4w/usr/src/grass_trunk/bin.i686-pc-
 mingw32/gem70.exe OBJ.i686-pc-mingw32/actions.o OBJ.i686-pc-
 mingw32/at_exit_funcs.o OBJ.i686-pc-mingw32/error.o OBJ.i686-pc-
 mingw32/main.o OBJ.i686-pc-mingw32/reg_deps.o OBJ.i686-pc-
 mingw32/reg_entries.o OBJ.i686-pc-mingw32/reg_html.o OBJ.i686-pc-
 mingw32/tools.o /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/lib/fmode.o
 OBJ.i686-pc-mingw32/actions.o: In function `unpack_extension':
 c:/osgeo4w/usr/src/grass_trunk/gem/actions.c:99: undefined reference to
 `mkstemp'
 OBJ.i686-pc-mingw32/main.o: In function `main':
 c:/osgeo4w/usr/src/grass_trunk/gem/main.c:585: undefined reference to
 `mkstemp'
 OBJ.i686-pc-mingw32/reg_deps.o: In function `register_extension':
 c:/osgeo4w/usr/src/grass_trunk/gem/reg_deps.c:127: undefined reference to
 `mkstemp'
 c:/osgeo4w/usr/src/grass_trunk/gem/reg_deps.c:212: undefined reference to
 `mkstemp'
 OBJ.i686-pc-mingw32/reg_deps.o: In function `deregister_extension':
 c:/osgeo4w/usr/src/grass_trunk/gem/reg_deps.c:281: undefined reference to
 `mkstemp'
 OBJ.i686-pc-
 mingw32/reg_entries.o:c:/osgeo4w/usr/src/grass_trunk/gem/reg_entries.c:282:
 more undefined references to `mkstemp' follow
 collect2: ld returned 1 exit status
 make: *** [/c/osgeo4w/usr/src/grass_trunk/bin.i686-pc-mingw32/gem70.exe]
 Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/930>
