[GRASS-dev] [GRASS GIS] #932: Wingrass7 - ImportError: No module
named grass - Fix PYTHONPATH?
trac at osgeo.org
Sat Feb 13 18:02:29 EST 2010
#932: Wingrass7 - ImportError: No module named grass - Fix PYTHONPATH?
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: | Platform: MSWindows Vista
Cpu: x86-32 |
self compild grass7 in the osgeo4w-stack
if i want to start for example
''v.db.addcolumn'' from the wx-table-manager, there is following error:
File "C:\osgeo4w\usr\src\grass_trunk\dist.i686-pc-
mingw32\v.db.addcolumn.py", line 52, in <module> import grass.script as
grass
ImportError: No module named grass.script
in the wiki
(http://trac.osgeo.org/grass/wiki/CompileOnWindows#Troubleshooting) there
are a few hints for troubleshooting, so also for
scripts/*[[BR]]
ImportError: No module named grass[[BR]]
Fix PYTHONPATH to *nix-style (eg. PYTHONPATH=/osego4w/apps/Python25)
so if i change this in c:\osgeo4w\etc\ini\msys.bat
(following
http://trac.osgeo.org/grass/wiki/CompileOnWindows#Grass-7.0.svntrunk),
then v.db.addcolumn works.
so where should this change integrated directly in source for working
wingrass7 out of the box?
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/932>
