[GRASS-dev] Re: [GRASS GIS] #886: improve module wxGUI tab logic
trac at osgeo.org
Sat Feb 13 22:39:50 EST 2010
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by hamish):
Replying to [ticket:886 hamish]:
> I propose guisection->_("main") (important|core|primary|...?)
> as the first module wxGUI tab, which[[BR]]
> * Required=YES options are automatically assigned to,[[BR]]
> * and other options can be assigned to it as needed...[[BR]]
> the Required tab, while usually doing the right thing, is too
> blunt an instrument for all cases.
also this allows to have input= or output= on the front tab even if it can
be optional due to a flag that prints some info to the terminal and exits.
Forcing users to specify output=dummy to overcome Req=YES + `--list` style
flags isn't a very nice solution, when Req=YES is just there to force the
important option on to the front tab for visibility.
any thoughts?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/886#comment:1>
