#96: v.surf.bspline column option broken
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: Raster | Version: unspecified
Resolution: | Keywords: v.surf.bspline
Platform: All | Cpu: All
Comment (by cmbarton):
I just tried out the updates in GRASS 7 trunk. The column option still
doesn't work right. v.surf.bspline runs without complaining if you specify
a column, but the output is a flat map that does not use the column values
for interpolation.
Also, the layer selector no longer gives a -1 option in the GUI. So you
cannot use a 3D map either.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/96#comment:14>
